Jamie
I have now returned from a 4500nm trip across Australia and back in my Vans RV-7A.
I would like to say that Skyview worked well for my adventure across OZ.
The only problem I had was #1 cht cable needs to be re-crimped. It would sometime jump into the red zone, just like
an open circuit. The EGT stayed the same, so I knew that it was just a cable problem.
In the middle of Australia, you can see lots of... well nothing, so a good gps and map software is a must.
I have the full moving map software for skyview and the Jepp database with obstacles.
The database has nothing to do with skyview, it all from Jepp. If you are IFR, then this would be great,
However for me as a VFR pilot, I found the database very lacking.
What I found myself doing is set the destination
Airport into skview and used my Ipad for track between all the smaller airfields that are not in the jepp list.
I have the one year service from jepp, when that runs out, I will be looking at pocket FMS as the new database.
The fuel computer is great, I knew how much fuel I needed at each stop within just a few liters.
With the full set of engine probes I was able to get the best out of the lycoming 0-360A1A.
Lean to LOP is easy, just a press of the "lean' button and pull that red knob back.
Here are some shot of the trip, enjoy.
