henriquerv7
- Joined
- Feb 13, 2009
- Messages
- 8
Hi,
I have and D100 and D120 installed in my RV7. My last upgrade was for the firmware 3.0 in both units and everything worked great. But when i try to upgrade to 5.0 the following happens :
1 - when connecting the serial port on D100 and D120, the dynon pc programs recognize that exists a unit connect to PC (but doesnt tell wich one is it).
2 - when i asked to detect firmware version, the dynon screens change to yellow and the dynon pc programs and also the equipment seems stop responding. This happens in both D100 and D120. So, i have to end the program and power off the dynons. After turning on again everything comes back to normal.
I would like to know if you have any idea whats happening. the wiring i am pretty sure is correct since the first upgrade to version 3.0 was fine.
The differences from what i did in upgrade 3.0 basically is the PC operating system. First i was using XP professional and now i am using windows vista.
BTW, When installing the usb/serial adapter, windows vista didn'find the driver for it automatically on internet, as you said in your instructions, so i had to search for a compatible driver to install it. If you believe this could be the problem, is it possible for you to send me by email a correct driver for it?
Thanks in advance
Henrique Castro
Thanks in advance
Henrique Castro
