9Cyl Radial SV and metric pressures
dabear
Warrenton, Virginia
I asked this a while ago about supporting 9cy EGT AND CHT.  Orginally someone said it would be supported in SV, then it changed to would be supported in the future with a second EMS.  Y'all build a GREAT product and I love the SV.
Any chance I can get into the beta of a second EMS for my CJ?  or any SV Beta
Also any chance the SV could support pressure measured in kg/cm^2?  It's what I've flown behind for the last 10 years and is what I'm used to.  Thanks for supporting kph and Deg C.
Respectfully,
dabear
Warrenton, Virginia
With the 60amp B&C Alternator, I don't think I have much concern over power draw. Although the orginal engine came with a 200 amp generator. ;D
I have 2 10" SV in the front cockpit (1 as PFD, 1 as MFD and backup to PFD) and 1 10" SV in the rear cockpit. I thought about using a D6/D10/etc as a backup, but I think it makes better sense to use the SV if you have the pannel space. Price difference is not much once considering the price of all the other components and that the backup can still run the AP if required.
Looking forward to trying it in IFR once I get used to the layout.
One one EMS module, there are 14 thermocouple inputs for CHTs and EGTs, and they are arbitraily assignable. In other words, you can have 9 CHTs and 5 EGTs, or vice versa. We don't yet have a timeframe for dual EMS module support, so we don't have any beta equipment or program to possibly involve you in at this time.
8181C
Bear love to see some pixs of your installation. Just finished mine in my CJ and will post a pix when I get the chance to get one.. :D
dabear
Warrenton, Virginia
Dynon, I realize there is a lot of other things higher priority than two EMS in the SV list. However, still asking is there any chance of pressure readings in kg/cm^2? Might be an easy change.
As for pictures, I'll try and get some out in the next week or so.
Thanks for the suggestion. It's now added to our queue of suggested enhancements.
It only lets you attach imaged on new threads. A lot of people use the free image hosting sites and link their images from there in their posts.
You can insert an image inline using the
Code:
[IMG]http://www.digitalmapping.sk.ca/canrockies.jpg[/IMG]
of course you'll want to use a link to your own picture.
