khorton
Attitude and Heading Reference System - AHRS (not AHARS) is not the same thing as Inertial Naviation Systems INS (or Inertial Reference System - IRS). An IRS is an INS that also outputs attitude and heading information in addition to the position info. AHRS is somewhat similar technology to the attitude and heading reference from a Dynon EFIS. INS requires sensors with several orders of magnitude greater accuracy (and cost), and the higher sensor accuracy allows determination of heading during the initial alignment, and continuous integration of accelerations to determine position via dead reckoning once the initial position has been input to the unit. Comparing an AHRS to an INS is like comparing a bicycle to a new Mercedes car. For a good description of the state of the art in INS 9 years ago (and the state of the art has likely improved since then), see this article. Note that it discusses gyro drifts (e.g. heading error) of a few thousandths of a degree per hour, and navigation errors of around 0.6 nm/hour, without any GPS or other (i.e. heading) aiding.In this document is mentioned Group 20 aircraft (which includes Airbus’) who's “AHARS systems typically have rate gyros, magnetic compass or GPS inputs feeding into a computer which calculates heading for display”.
I've worked full time as an engineering test pilot since 1988. I've done flight testing on over two dozen different models of aircraft fitted with INS (or INS). I have a good understanding of the INS inputs and outputs for most of those aircraft. I can assure you that most civil INS (or INS) achieve amazing navigation, attitude and heading accuracy without any input from flux valves, inclinometers or GPS. Just because you don't understand how something works doesn't mean it doesn't work. It just means you have some more learning to do.
The systems descriptions in the aircrew documentation for most modern aircraft are very simplified, and crews are no longer expected to have an in-depth understanding of how things actually work. They are simply expected to correctly apply the recommended procedures in response to various system indications. Things were quite different back when aircraft were simpler - then crews were expected to have a very deep understand of what was actually happening, but modern aircraft are so complicated that it is no longer reasonable to expect the crew to understand all the layers of the onion.This was the best I could come up with on short notice but it is not based on the opinions of Airbus Drivers (who appear to be pretty clueless how their “Magic Bus” actually works). Kinda scarry don't you think?
