ADA network cable
WrightsRV7
Am a bit confused on the number of wires used in the network cable going from the ADA to the SVD-1000. The CP network cable comes with 7 wires and does not match the color code for a network (9 wire) plug, seems to be for the autopilot. What is the correct wiring for the D9 to go from the ADA to the display? Can I use 7 wire D9 plug as supplied with the ___CP one ended cables or do I need all 9 wires filled in the connector?
Cheers, Mike W. :)
We don't sell anything called an ADA cable, but any of our "normal" SV-NET-XXX network harnesses should have 9 wires in the DSUB connector. The Autopilot harness - the SV-NET-SERVO, omits two power wires because it doesn't draw power from SkyView Network, and hence can't take advantage of the reduantant power lines. So that does indeed have 7 wires.
