ADAHRS "T" location?
Steve SR
To use an ACI Gear Alert in my SeaRey I have to run a line/tap into the pitot feed line, the Gear Alert (https://flyingsafer.com/2080) is the black box mounted vertically behind the ADAHRS, and the simplest thing would be to tap off it as shown. Any problems with it being this close? Yes, it will all be secured down.
TIA
Steve SR - FWIW - are you using or have considered using the SV-MAG-236 remote magnetometer ? you may need to due all the ferris metal parts in the area of the ADAHRS -200.
Steve SR
Hi Jake,
Thanks for the heads up, I asked my SeaRey Sensei (Jim Ratte, The SeaRey Specialist https://seareyspecialist.com/), he's been building SeaRey ever since they came out and has never used a remote magnometer in his builds so I'm leaving it out. I can always add one later if I need to.
