Adding AFS-5600 to Dynon D-100/120 panel
lawdogf16
I have a D-100, D-120 & HS34. I am getting an AFS-5600 (with the SV-ARINC 429 network) and getting rid of the D-120. I am keeping the D-100 & HS34. Is there any way to wire my 430W GPS individually to the 429 and D-100 or must I splice off the current connection to the D-100. I was thinking I could connect the 429 and 430W through ARINC and the HS34 & 430W through serial.
If you use the serial connection to the HS34, you'll lose the NAV radio side of the 430's output. Also, the GPS won't do things like auto-scaling of the needle and such on the D100's HSI.
There's no reason you can't split the transmit side of the 430's ARINC to both the AF-5600 and the HS34. You'd probably want to have the AFS unit transmit back to the 430 though and move that half of the connection off the HS34.
