ADHARS boot issue
Fly4fude
The last few days I've begun having a problem with my ADHARS not booting up. When I turn on my power and avionics swtches Skyview boots up normally, but the PFD shows a red X and a warning message of ADHARS Fail.
When I shut down the avionics switch and the system begins its 30 second countdown tha ADHARS will come on MOST times.
Once on turning the avionics power back on will keep everything up and running.
I have the following setup:
28volt system
Two 7" screens (one with a back up battery)
One ADHARS
ONE Dynon gps
Two servos
Any thoughts?
I have chcked aircraft voltage of 24 on batteries and 28.3 with engine running
Thanks for your help!
A couple of places to look. When the system is in this state, what do you see under SETUP MENU > SYSTEM SETUP > NETWORK SETUP > NETWORK STATUS under the ADAHRS? And if you have the ability to see the red LED light on the physical ADAHRS, what is it doing? Are you getting any kind of network error in the message area?
