paulrkuntz
- Joined
- Apr 12, 2011
- Messages
- 21
I installed a Dynon SV-XPNDR-261 Class 1 Mode S transponder and SV-GPS-2020 GPS receiver earlier this year. I had a local avionics facility perform a transponder check, then flew locally for a system check. I requested an FAA ADS-B Compliance Report, which came back reporting no exceptions. So far, so good. A few weeks later, out of curiosity after a longer interstate cross-country flight, I requested another Compliance report. This report came back reporting non-compliance for the NIC (Navigation Integrity Category) parameter. The NIC values in the non-compliant report were: % Fail 2.81%; Max dT 00:00:03; MCF 7; Avg 8.7; Min 0; Max 9. The FAA User Guide for the Compliance report says little regarding NIC other than a minimum NIC value of 7 is required, and that NIC values less than 7 will be flagged red in the report when the MCF (Maximum Consecutive Failures) threshold is exceeded. The NIC MCF for the first (compliant) report was 3, so apparently the MCF threshold for NIC is somewhere between 3 and 7. The average NIC value of 8.7 for the non-compliant report is better than the required minimum of 7, but the minimum value is 0, so I infer that I was squawking a NIC value of zero (or some value less than 7) for more than some unclear number of consecutive reports. I'm not sure where to go from here. At the moment I'm inclined to do nothing. I have one fully compliant report from the FAA that I can refer to if I'm challenged, and frankly, an MCF of 7 really doesn't seem all that bad. It means that at some point during the flight my position reporting was outside the required integrity level for up to seven seconds. I would be worried if the interim value were not compliant for tens or hundreds of seconds. Does anyone else have experience with diagnosing and resolving a similar ADS-B compliance issue?
