ADSB out question
Doug94
After conducting the FAA ADSB out test I am not putting out an "Out" signal. My set-up is an original skyview, Garmin GNS 430W, Model 261 Transponder, ADSB model 470, and a Skyview GPS puck antennae. My setting in the set-up menu are correct (identifies a non-dynon ADSB-out). Is my issue with the Skyview antennae being the original issue GPS puck? Or should my settings be to use a Skyview ADSB - out device? The ADSB - in works perfectly - I get traffic and weather. Thanks, any direction to try and resolve the issue would be appreciated.
GalinHdz
KSGJ/TJBQ
To start, which GPS position source are you using? If using the G430W, it must have GPS software version 5.0 or higher and the RS232 output going to pin #2 of the transponder (through a 1.2K Ohm resistor) must be set to the ADSB+ format. If you are using a DYNON GPS puck, only the GPS-2020 puck will provide a correct ADS-B "Out" signal if configured correctly. The older GPS-250 puck is not an ADS-B "Out" compliant position source.
I love aviation!
If you have the GPS-250 puck set as your ADS-B out source, it will not pass the test. Either use your 430W (assuming proper firmware update) or replace the 250 with the GPS-2020 antenna.
