ADSB System Check
apkp777
Received my ADSB "System Check" from the FAA today. So what's the Skyview solution to a failed SIL and SDA?
I have an all-Skyview system (ADSB, GPS, TRANSPONDER) my SIL and SDA values fail with "0"'s as output. I am guessing I need an "approved" GPS (TSO, etc). Is that correct?
  • N524AP_-_ER_20140521_A697D8_1117519.pdf
Yep, that's right. SkyView + the ADS-B output isn't a 2020 compliant emitter. Fortunately, you'll see that the FARs don't require one until 2020.
To follow the trail (excerpt of the two relevant regs below - the bolded bits are what tie everything to 2020 and beyond):
§ 91.225 Automatic Dependent Surveillance-Broadcast (ADS-B) Out equipment and use.
(a) After January 1, 2020, and unless otherwise authorized by ATC, no person may operate an aircraft in Class A airspace unless the aircraft has equipment installed that...
(b) After January 1, 2020, and unless otherwise authorized by ATC, no person may operate an aircraft below 18,000 feet MSL and in airspace described in paragraph (d) of this section unless the aircraft has equipment installed that—
§ 91.227 Automatic Dependent Surveillance-Broadcast (ADS-B) Out equipment performance requirements.
(c) ADS-B Out Performance Requirements for NAC P, NAC V , NIC, SDA, and SIL—
  (1) For aircraft broadcasting ADS-B Out as required under § 91.225 (a) and (b)—
So, basically, until 2020, there aren't any requirements that you meet the 2020 performance levels, although if you had a certified GPS like a 430W or GTN directly connected to the transponder, you'd pass that test. However, like many things with non-certificated (amateur-built) aircraft, we know of no regulatory requirement that even requires an ADS-B system check for non-certificated aircraft even if you did have the fullly-certified stack to be a 2020-compliant installation.
apkp777
Dynon,
So...are you guys considering developing an "out solution" for Skyview?
It would be nice to have full compliance sooner rather than later. Given some ATC facilities are already using ADBS traffic separation.
GalinHdz
KSGJ/TJBQ
I got my FAA ADS-B "System Check" report today and I am 100% compliant!  :D I have a Skyview system (Xponder & ADS-B Module) connected to a Garmin 430W. It works very, very well.
If you want to know how your ADS-B system is performing send an email with N-number to: 9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov and request a detailed report.
:cool:
