Advanced Aircraft Electronics L-2 transponder antenna?
You need to be more specific. An EFIS (Skyview) doesn't use antennas. Do you mean radios, transponder, ELT??? I understand these are pretty good antennas for composite aircraft because the ground plane is built into the antenna itself. Should work well in a fabric aircraft too if you keep it away from the metal structure. But this would be a terrible choice for a metal aircraft.
Steve SR
Apologies, should have been more specific. It's for the 261 transponder.
Here is the answer from the Mothership:
Dynon Tech Support said:
As long as the antenna is optimized for 1090 MHz and compatible with mode S level 1 transponders, it should work.
Technical Support Specialist
(425) 224-6736 Support Phone
425-402-0433 Main
www.dynon.aero
[/dynon]
I've got an inquiry into AAE, will let you know when I know.
GalinHdz
KSGJ/TJBQ
I used that exact antenna in my fiberglass KIS4. One for the XPNDR-261 and one for the ADSB-470 IN module. They are superb and am glad I used them.
