Airmate map issue
Avee8or
What is the solution? My display gives a big blank area where a sectional and TAC chart meet. My home field just happens to be in that area! I do not see any options for turning off the TAC chart display. WOndering how to get rid of this annoyance!
Interesting. What prompted this? Was there a chart or software update installed when this started?
Avee8or
I updated charts. Prior database was 6 months older as I have been on extended absence from home. Tried re downloading on fresh usb stick but problem persists. Next update will come soon so hoping the problem disappears.
Sounds like an issue with Airmate. I doubt it would help, but you might try resetting your map settings.
Avee8or
Thanks. Didn't work. Still awaiting response from Airmate and Dynon. New database coming shortly; will see if that fixes it. Will try a friend's Seattle Avionics database to see if that narrows the problem to airmate.
Avee8or
For what it is worth, neither Dynon nor Airmate have responded to my emails regarding this issue. Dealer also unable to help…never saw this problem he says. Disappointing.
Avee8or
Dynon did respond and got word from airmate. Aware of problem, thought it had been fixed. Problem persists with latest database download. I never heard from Airmate, and happy with Dynon support.
I had some issues with Airmate previously. They had been very responsive. The last 2 times I needed help I didnt hear anything. Disappointing.
Avee8or
Well, the latest airmate DB update still has the problem. Pity I just renewed or I would switch to Seattle. Going back to see if Airmate is any more responsive than before. (Low expectations!)
I also had a problem with last download. Contacted dynon and they said it was an airmate issue. Had a funky taxiway intersection leaving the ramp and the Geo referenced plate wasnt showing me where I was. I obviously was still on the taxiway but the plate had me quite a bit off of it.
Sent the pic to airmate and got a response that they would inform the proper people. Dynon had said airmate had been very busy. Might be a case of you get what you pay for. My sub ends in the fall, will see how it goes until then.
Avee8or
Dynon more responsive for certain! Maybe Airmate detected those bushwheels on your bird and decided you were going off paved runway! :cool:
