Airport Diagram Position Accuracy
MikeD
KPYM
What is your experience using Skyview HDX to help navigate complex ground routes? When using this at my home airport, the accuracy of my location is abysmal. See screenshot of me on the taxiway after landing. While I was tracking the taxiway centerline, Skyview showed me well off into the weeds!
I didn't think to cross check this issue on my EFB. Will do so at the next opportunity. This will help determine if the FAA diagram is inaccurate or if it is a Skyview bug.
Support ticket submitted. Will post an update when Dynon replies.
I use the taxi diagram every time and it is always spot on. Does it do that everywhere or just at your home field? Is it consistently off in the same position? Maybe you have a bad reference on your airport diagram.
Back
