airspeed correction
ljbuller
ND
I know there is a way to adjust altitude.
Is there any way to correct indicated airpeed?
I will recheck alignment of the pitot tube, but assuming it is good can the airpeed be adjusted like the altitude?
There isn't, though we'll probably add a way to fix very low airspeed airspeed calibration creep which is sometimes seen over long periods of time. The D10/D100 has this in the form of the "zero airspeed calibration", or SPDCAL menu item, already.
The reason this is offered at all is that very low airspeeds (<20-30 knots) are basically thousandths of psi of difference, which are against the edge of detectability.
Mostly, though, IAS == dynamic pressure, period. The cause of most systemic IAS issues are problems with the static placement.
S
stede52
Re: airspeed correction/static placement
Does anyone have an opinion on the best place for static placement in a tube and fabric airplane. I currently have two, one on each side of my boot cowl, wondering if that is a bad placement.
Steve
trevpond
Nottinghamshire U.K.
Du, I hadn't thought of that!! Clot!!
Perhaps the question was badly phrased! I reckon my SV is a couple of mb adrift, hence the question.
Trev ;D
Off the top of my head (at Osh, not in front of a unit), I think it's under setup menu >hardware calibration > adahrs.
