Installed: Skyview HDX and VP-X with Primary Alternator monitoring disabled because I have a permanent magnet Alternator
In VP-X Configuration, I've disabled the Primary Alternator circuit (actually cycled it from enabled to disabled as recommended for Rotax applications) but still getting a fault in the Dynon/VP-X display on the Alternator. It's like the Dynon will not recognize the VP-X Configuration without this alternator circuit, and when it doesn't see voltage as the engine RPM increases, it throws the fault alarm.
How can I get the Dynon to ignore the disabled alternator field circuit?
Thanks,
Scott
Thanks,
Scott
