Altimeter Correction
Randy
I just had the Pitot/Static and XPNDR test done by a qualified technician. He dialed the test to 10,500' and my Dynon altimeter showed 10,460'. Is there a way that I can dial in a 40 foot correction in the Dynon HDX system ? If so, how ?
Kevin D
Not with the documentation at the moment and hate to be the one to say it is in the manual without reference but the procedure is in there.
A more relevant question is what were the values and errors at other points from sea level to 10,500?
Randy
It is 40' off consistently throughout the climb, e.g. when 5000' true (and tranmitted via xpndr) my HDX show 4960'. It is not off by a %. At field elevation, I am 40' off.
GalinHdz
KSGJ/TJBQ
What do you mean by "5000 true"? The transponder sends out pressure altitude (not compensated for barometric pressure) to ATC. The ATC RADAR display adjusts for the current barometric pressure in the area you are flying. Make sure you are NOT using GPS altitude as "true" altitude. It will rarely be the same as XPONDER reported altitude.
Did it pass the XPNDR test done by the technician?
A qualified tech should have known this, as well as all the other info from Dynon on how to conduct a static/xpdr test, including adjusting the offset for the altimeter (it's in the manual; see above post). Mine did.
Randy
RV8JD, your response was spot on and very much appreciated ! That was exactly the input I was hoping for. I will now "make it so".
