jnmeade
I fly to several unregistered airports. I add them as User Waypoints. There is a data entry for altitude in the User Waypoint construction box, but the HDX manual says altitutide in that database is informational, not used for navigation. HDX manual ed P 5-65. Therefore, it does not show up in the optional Map Info column on the right side of the display. As a result, the VSR data block at the bottom of the Map Info display is vacant. I often refer to that info to plan a descent.
I see in inference in the forum that one can not add an airport. The altitude of the airport is used for navigational purposes. So, it appears I can not add an airport and cannot use the altitude in the User Waypoint for navigational purposes. I'm stymied.
Does anyone have an idea for a way to get a VSR descent rate presentation for an off-airport site?
