Bardample
- Joined
- Aug 18, 2013
- Messages
- 41
I have 375 hr Skyview Classic set up on RV7a. Yesterday the ammeter ( that usually reads 7 amps Alt output at cruise) alarmed and gave negative readings, with highly variable numbers. The voltage reading from my B&C Alternator remained steady at 14.3 volts . I concluded it was a loose fitting or fault in the Skyview , as the Ammeter retuned to the “ usual “ 7 amps at cruise. Apart from one or 2 other warnings , the next few hours remained ok for the next 4 hours of flight.
I checked for loose connections , none found . Other wise all else ok .
Whats the most likely diagnosis?
