Ammeter shunt -- protection enclosure (isolation)
lolachampcar
I copied the shunt sensor deffinition and renamed it to myplaneshunt or something like that then changed the cal until it read correctly. It was a nice simple solution using the already existing wiring (which provided more signal for a given current). I'm sure the temperature stability is not as good as the shunt provided by Dynon but that is such a small error that it really will not matter (especially given that the display rounds to the nearest amp).
sensor={
id=AMMETER SHUNT (100412-000)
function=AMPS
pins=C37_P24/25
name=BATT
name=ALT
name=LOAD
min_val=-100
max_val=100
resolution=0
round=1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=1000
c_x0=0
low_resistance=PULL_UP_200
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high_resistance=NONE
high2low_cross=0
shift=5
ggerhardt
sensor={
function=AMPS
pins=C37_P24/25
name=BATT
name=ALT
name=LOAD
min_val=-100
max_val=100
resolution=0
round=1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=1000
c_x0=0
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
shift=5
Where in that sensor definition do you put the scalar?  I don't see it anywhere.
Thanks.
Geoff
kastein
Wire Nut
Southbridge, MA
A few things -
- yeah I know this is a pretty old thread.  It answered the question I had (how to set up custom ammeter shunt mV/A scaling) but raised a few very important points in my mind.
- first of all - make sure the shunt is mounted on a vertical surface, with the terminals in a horizontal plane, so that natural convection cools the flat manganin alloy resistive elements.  If you don't, you have to derate the current rating quite significantly in some cases.
- second - it shouldn't be covered!  if it is, make sure the cover doesn't affect cooling air flow.
- third - using the alternator feed wire as the sensing element is a clever solution, but please check (I can't remember) if the thermal coefficient is better or worse than a typical manganin current shunt.  If it's worse, you will have less accurate readings at elevated/lowered temperatures than you would with an actual current shunt installed.  If it's better, congratulations!  You win both ways. edit: I missed that the third point was covered by lolachampcar on my first reading, sorry!
I can't post a direct link since I haven't made many posts on this forum yet, but if you google search for "murata dms accessories 3020-01097-0" the first result is an excellent datasheet from MuRata on their current shunts.  Page 2 covers thermal derating.
I am not sure what brand/part number the Dynon shunt is, or whether a derating for aircraft use has already been applied, but I would strongly recommend not preventing convection cooling air from reaching the shunt.  It'll cause inaccurate readings and can damage the shunt.
MWDG3
Old post but it might be useful to someone.  MS18029 terminal covers come in a variety of lengths and widths.  Pricing varies wildly so research which length you need to modify for the shunt's mounting screw hole dimension.  Running a 10-32 or 8-32 bolt through the bottom with MS21042 steel lock nut would make a very secure installation.  No idea if a #8 0r #10 nut would inside the mount recess.
randbelectronics dot com/Catalog/CATALOG.pdf
