I have been working thru AP issues for the last two months. Issues that included pitch control issues and constant roll slip and pitch slip indicators. Dynon support helped resolve many of the issue. One additional issue that just came up is: Each time I start up the plane the AP panel is not recognized on the network. In turn that renders my pitch trim in-op. Pitch trim is wired to the AP panel for auto trim. This new problem came to be when I replaced the AP panel at the request of Dynon. The new AP panel is on the new software version. If I go to; detect auto network configuration the AP will not show up. If I force network configuration The AP panel still will not show up. When I remove the AP panel unplug it and reinstall it will work. This process must be repeated each time the aircraft is shut down. This problem did not exist with the other AP panel I sent in. Any thoughts would be greatly appreciated.
Wiring harness has been ohm'ed out on each connector.
