AP pitch/roll error on startup
tatomir
AP, Dynon Skyview, 10 inch, latest software(HSI + ALT)
I get pitch/roll error on star-up very often. I need to re-start the engine in order to get rid of the errors. It is very frustrating.
Is there a special trick ? Can I  touch or not the stick till Dynon starts us ?
Any advice is much appreciated !
Dan
A few questions:
What is your order of power up operations (master, avionics power, SkyView, Servos, engine crank, etc)?
Is the event related to engine cranking?
If equipped with either an AP switch or breaker, have you tried turning them off and on (instead of restarting the engine)?
tatomir
==> Master ON, Engine ON, Avionics ON(When Avionics ON => Dynon + AP ON)
==> NO, I don't think so,
I tried to turn off/on Avionics while the engine was running and I got the same error message.
Any idea ?
Your
Thanks in advance,
Dan T.
tatomir
Any idea ? This problem is really annoying.
so, the order is :
1. master on
2. start engine
3. avionics on (dynon..etc ON)
Sometimes I got only pitch or roll error.
Thanks in advance !
Dan T.
tatomir
I get this error after I follow these steps :
1. master on
2. engine on
3. dynon on (avionics on)
In order to get rid of the error I need to stop the engine and follow the steps again. It is very annoying since it is happening very often. (2 out of 5 times)
Dan
BGK - what you're seeing is expected in your installation. The servos probably aren't getting power until you flip the avionics master. This is why we generally recommend that they be powered up on the same switch as the rest of the Dynon system.
BGK
Correct, your A/Pilot servos are powered on via the Avionics switch.  HOWEVER with the VP-X ( I just love that system) we can simply change it over, via the VP-X config menu, to the same 'always on'  function as the Sv's without any wiring changes - simple  ;)
Jake J
tatomir
FIXED :)
Now the AP servos are connected to 'avionics'. (before were connected to 'master')
However, while the engine is running if I want to reproduce the problem I switch on/off the 'master'(or 'avionics') a couple of times. Is it normal ?
Dan T.
How fast are you clicking on and off? We don't specifically test pretty fast power cycling, so if you're bringing things up and down over a few seconds, you might be able to encourage odd behaviors.
Bradrv7A
BGK
Jake J
What is the VP-X system? Is the config menu the menu in the dynon autopilot? What are Sv's?
Bradrv7A
I'm new to this. Happy to learn from others. I've got an EFIS D100 operating autopilot. I get the same error messages on start up (not always, but becoming more frequent). The servos are connected to the master and the dynon to the avionics master. This is the way the builder put it together. I haven't got the vpx system installed, which means, I guess, that the servos need to be rewired to the avionics master, or the breaker cycled or the master cycled on/off? Any other suggestions welcome
