AP Servos & ADAHARS not detected
jaybhansen@gmail
Dual D1000 HDX - Neither the ap servos nor the adahars are being detected. and below the first SV Display I am getting a 'Skyview Network Connection Fault - Data 2 Pair (Pins 4 & 8)'. Are these items related? Anyone have an idea to fix this?
Probably. First, disconnect both cables from the display, and do a network configuration. Are you still getting that error? If so, it may be the display. If not, it's probably the SkyView Network cable, or possibly one of the devices. That error is telling you that something is up with the wires on pins 4/8. Assuming you pass the above test, if you have two network cables going out from the display, you'll want to connect / detect with them connected individually to start narrowing down where the issue is.
Have they EVER been detected? If not, are they definitely receiving ship's power? Note that the servos don't wire quite the same way as other SkyView Network devices. Instead of being powered by the SkyView Network cable themselves, they should have dedicated higher current 12V power/ground going to their power wires.
