ARINC-429 menu de-acivated
ds3fch
Daejeon, Korea
Hi, everyone.
Two Dynon SkyView Classic SV-D1000 have been installed on the CTLS of my flying club member.
He had pressed some wrong buttons during the setup modification (he does not remember what) and co-pilot side SV-1000 does not shows the map anymore (just X-mark)
SV-ARINC-429 module is already installed and was working properly before that.
There was no hardware modification or repair, etc...
At the system setup menu, ARINC-429 sub-menu is disabled and can not enter that menu.
Software version is updated to the 16.0.1
During the booting, "DATABASE IS NOT CURRENTLY LOADED" is displayed.
How can I revive ARINC-429 ?
Any comments will be appreciated.
Thanks.
cbennet12
The ARINC talks to the SV via the SV network. Check the Network Status to make sure the ARINC is identified. If not, try the scan/detect devices option.
Palmer180
I'd try this: SETUP>NETWORK SETUP>CONFIGURE
Then check: SETUP>NETWORK SETUP> NETWORK STATUS
maartenversteeg
I would suggest first checking the network status. And then when the ARINC is not part of the recognized units the trying to configure and finally check again the network status. (so that at least you have some idea what the status was before trying a reconfiguration)
ds3fch
Daejeon, Korea
I've re-checked the network status, but can not find ARINC(ADS-B).
SV-ARINC-429 is installed and power is on.
The cables and connections are not touched after installed.
Do I have to check the physical electric connection?
maartenversteeg
Not clear what you mean by ARINC(ADS-B). But clearly there is currently no SV-ARINC-419 configured in the network. So after having determined that this is the case the next step would be to try to see if the system can find the SV-ARINC-419 by doing a network configure: SETUP>NETWORK SETUP>CONFIGURE
ds3fch
Daejeon, Korea
SV-ARINC-419 does not appear even after network configure (many times...): SETUP>NETWORK SETUP>CONFIGURE.
kellym
If network configure does not find the ARINC-429, then you have developed a loose cable connection or other wiring problem.
