thx for these warmhearted words
of course ivé read it, but at the end, there is no chance to switch on the ATTITUDE on my PDF. And your advice helps not really.
Actually, I meant it just straight because I was unsure of your English skills. i.e. wasn't sure if English is your first/only language and I can easily be misunderstood. I interjected no humor and no offense was intended. If you read the manuals, I thought (my mistake) you would have the material to understand the menu structure and what was being missed.
It would also help if you explained what you see and what you don't?
1. Do you see any red X where you expect something?
2. Do you just see EMS or Map or Both Map and EMS, but still no PFD
Your comment above:
Sorry, there is nothing to select.The layout button is not highlighted and the rest is BAc, Dim,pfd, ems,mao and swap. So, what have i to do????
Since you have a "back" button...You are not in the top menu level of the screen. Keep pushing back until you get to the top level.
If you don't see big red X where the PFD should be I'd recommend checking:
1. In setup menu, list each of the devices in the network.
Are the Two ADHARS there?
Are they the same software version number?
2. exit Setup
If both ADHARS are NOT in the network device list then you need to finish install to get them working. If they ARE in the network list:
1.Keep hitting back key until you see screen key. follow advice in other post.
If you DO have big red X where PFD should be, then I'd recommend troubleshooting the connections (wiring, network config, software).
Just trying to help.
