When the servo is slipping, the autopilot isn't able to control the airplane because the force to control/move the control surface is exceeding the servo's output. In turbulence, this can be very momentary, but, if it's routine or for a long duration, either the servo is sized to small for the aircraft, the install isn't ideal (not using enough of the servo's rotation, assuming you can use more without getting close to going over-center), or there's something up with the servo.
