Autopilot not working after upgrade to 3.2
parafingoose
After completing the 3.2 software upgrade my Dynon autopilot is no longer recognised by my 7" Skyview display. what have I done wrong?
parafingoose
Hello Trevor,
No, I did not have the servos switched on. They were not powered at all. Is that significant?
trevpond
Nottinghamshire U.K.
They need to be on when you carry out the upgrade. When you have the servo's switched off and try to carry out an upgrade, it is not copied over to all items on your network. Do a network search in your config files, that should take care of it.
Trev
parafingoose
I guess I will find the config files in the setup menu after turning the servos on? I will try that, thanks. Dudley
Once you do a network configuration with the servos powered don, it should find them, update them, and add them back to the network.
