Aviation Data base
mataylor
Colusa, CA
I updated to the 15 04 but I keep getting the message that my maps are not up to date specifically the Aviation Data. I used method 2 to download the Aviation data to my USB drive tried to load, but the message "No compatible files found in the Main Folder of the USB Drive."
"Files in Sub-folder can not be accessed by Skyview."
I need some guidance. I haven't run into this problem previously and I've updated many times.
If you used method 2, you need to download the aviation data separately from http://www.dynonavionics.com/us-aviation-obstacle-data.php. You should have (for this cycle) a file named FAA_av1701_ob1701_15.0.4.duc in the root of your USB memory stick that you then load to each display.
I love aviation!
I seem to recall having to load the map update separately as well, even though I used method 1 for the update to 15.4.
