Basemap resolution
rcostes
Dear Staff,
I have a two-screen Skyview system installed on my aircraft with a Pocket FMS aviation database installed. My two screens are connected by an ethernet cable. I don't understand why I have two different resolutions of the base map on my two screens. As you can see, the two scrennshots have the same scale but the river does not appear the same at all! The first pic is from my left screen and the second one is from my right screen.
Do you know any solution to that?
Thanks for your answer!
The terrain map that is different on your system is a 4GB file that comes from Dynon, not PocketFMS, and it is so large that we can't send it over Ethernet, so you need to update it manually via USB.
If you go into LOCAL DISPLAY SETUP->INSTALLED DATABASES, you will see Screen #2 probably has a "REG - 02 - NORTH AMERICA HIRES" TERRAIN DATABASE installed.
You can download the correct one for your region here:
http://dynonavionics.com/docs/terrain.html
