vlittle
- Joined
- May 7, 2006
- Messages
- 552
OK, let's face it. Charging the SV backup battery is a problem. We have two choices:
1) Fly the aircraft for several hours (I'm over 5 hours and it's still not fully charged).
2) Put a large capacity battery charger on the aircraft battery, turn on the Master Bus and come back in up to 4 hours.
Both of these have problems, especially if you have to charge the battery twice (once to get it fully charged for the battery test; the second to recharge after the battery test).
It's even worse if you have a critical flight coming up. The logistics of charging this battery is a royal pain.
My suggestion is to provide a separate ground power port for the SkyView system, to be used for powering up the SV or charging the SV battery. This port does not have to power up the whole panel and the master contactor.
A couple of suggestions are shown in the diagram. The first (A) is a 'zero drop' port. The second (B) uses diodes for automatically switching, but suffers from the voltage drop of the diodes which may be an issue for the minimum operating voltage of the SV.
Cheers, Vern
Cheers, Vern
