Hi Everyone.
I‘m building/assembling an ICP Savannah down in New Zealand, similar I guess to a Zenith 750 STOL, installing a Dynon Skyview system with autopilot. Luckily I’m getting a fair bit of help in this area because I know next to nothing about wiring and avionics.
I‘m installing the following electrical /avionic stuff from the rear fuselage forward in basically two bundles, port and starboard.
network cable x 1, strobe , nav and landing lights (all LED), elevator trim servo wire, com antenna cable, transponder antenna cable, GPS wires, headset jack wires, positive and negative 12volt cables from battery, PTT, and lastly autopilot servo power, ground and switching.
My very basic questions are given I can pretty much put anything up either side (but it will be easier to keep the bundles similar size, is there anything in this mix that I‘d ideally want not to bundle together and which of this stuff should be installed using shielded wiring.
Peter
Peter
