I have been running a dual SV1000 for a while on the ground in prep for a first flight. We were adjusting the idle and mixture settings, and during an enginer start, the pilot-side SV died. At first I thought the backbattery had died, but later confirmed it wasn't - if blue a fuse. That EFIS is powered alone from a 3 amp automotive fuse, which seemed to have exhibited a fast, high energy failue. I have started this engine dozens of time and never had a problem.
The backup battery for the copilot's EFIS has always been defective and we just recieved a replacement, but it was not installed, so that EFIS dies every time we do an engine start.
We used the Dynon cables for the wiring. I replaced the fuse and it powered up again, but we did no more engine testing. We run a PMAG for starting and there was no engine kickbacks or signs of anything that could have generated a voltage or current spike. I don't know how to download the Dynon data to see if that might reveal an issue in the making.
I presume the SV has internal TransZorbs for protection, but wonder that it might have been to cause the overload. Well, transzorbs will fail with a short, so I guess they would be ok. There was burning around the vaporized portion of the fuse wire, so I have to believe there was significant current event.
Any ideas? And how do you down load the data log???
Thanks!
Thanks!
