I have Rotax 912iS, with Dynon SV in a Sling2.   The ECU backup switch is used, with Lane A&B plus fuel pumps on, to “prime” fuel pressure, then turned off, before start. After 40 hours engine time I began getting a yellow “CAN Fault” message when turning on the ECU Backup. After the ECU Backup off, the warning message remains on. Once the engine starts, the warning message goes off.
If I “prime” with just the fuel pumps on, and not Lanes A&B, no warning message appears.
During the first 40 hours no warning message appeared. I’ve attached a few screen shots of fault warning, fault explanation, and CAN status.
Any help and suggestions would be appreciated. Thanks.
