Can I use a ground pin to serve two devices
Clotilde
Hi,
I have used all the ground pins available and need to connect "Fuel Level Capacitance converter to Voltage Converter" to D37.
Can I use the same ground pin, let's say #30, for both Left and Right Fuel Level Capacitance converters?
Thank you for helping :)
Clotilde
Spcialeffects
just been reading this section and yes you can. It says that the +5v, +12v and grounds is acceptable to share with other sensors
Hope this helps Frank
Hi,
Clotilde
Yes
Spcialeffects
Can things like fuel senders, FT-60 Red Cubes etc be earthed elsewhere i.e. at the main earth porcupine instead of through the EMS harness?
Thanks Frank
Robski
Hang on! I've got an idea!
I'll come clean and say I'm not certain, but...
Personally I would make sure the FT-60 Fred Cube only uses lines direct from the EMS to be absolutely certain that the clean 12v supply the EMS supplies doesn't get corrupted by a noisy ground.
On my EMS installation for a number of grounds I ran a ground line out of the EMS to it's mounting frame where I rivetted a line of 6 connected spades (a single piece fitting) and tapped any additional ones I needed from there.
As Robski says " doesn't get corrupted by a noisy ground" - I find the safest way, to save possible issues later, is to use a Dynon ground. I treat the EMS sensors the same way as audio - common dedicated grounds. ;)
