Can't change engine monitor parameters
russp
I'm running a Rotax 912iS and want to change the levels at which the fuel pressure warning are triggered but the Dynon won't accept the figures I'm trying to input, I can change from the defaults to a slightly higher value but not as high as I want to, and have been advised on the Rotax forums by rotax that is appropriate. It's really annoying on final at idle to get constant fuel pressure warnings. Only another 20 hours to my 200hrs when the fuel filter will be changed which will probably sort it - it's not a safety issue but it is annoying that I can't set the values to what I want to. Is there anything I can do about this please?
