ssbn608
I recently changed from a lead acid battery to a LiFePo battery for my main aircraft battery. Specifically, I installed an Earth-X ETX-680C battery. Compared to a 12V lead acid battery, the 12 v lithium battery has a different resting voltage, and different charge/discharge characteristics This suggests that I should be changing the red, yellow and green bands for the battery voltage on my SkyView display, and possibly for the ammeter, if the ammeter shunt is installed in position A for reading of battery charge/discharge current to/from the battery.
So, the question is.... what are the values I should be using?
The following is an excerpt from the Earth-x manual... I'm not sure exactly how this would translate into red, yellow, and green band settings, or alarm values for a voltage indicator on SkyView..
Voltage Monitoring Alert Recommendation (Existing Aircraft Equipment if applicable) The table below shows the recommended user alerts based on voltages when in flight. This pertains to existing equipment, and is not applicable if existing low or high voltage alerts do not exist or are not adjustable. The low charge level is very different from a lead acid battery, for a lithium battery is completely drained at approximately 11.5V, and the normal resting voltage is 13.3V. '
Note: this table pertains to existing voltage level warning equipment and is NOT associated with the Fault monitoring LED.
>15V High voltage warning
<13.5V Alternator off-line alert
<12.6V Low charge level warning
