Just completed installing the EGT and CHT sensors. Fired up the D120 and lo and behold all the CHTs and EGTs read -99 degrees. Removed a CHT sensor from the bayonet fitting warmed it up with a heat gun to where it si too hot to touch, still -99 degrees. This is in northern California where it's around +50F (nowhere near -99 degrees). Yes I checked the connections to the Dynon supplied harness. White goes to white, yellow to yellow and red to red. It is possible that the right sensor is connected to the wrong cylinder (I hope not) but electrically this should make no difference. Read the manual several times to see if there a soft switch I had to throw but Display is set to on. What did I do wrong?
HELP!!!
Best
Pat
HELP!!!
Best
Pat
