Class B altitudes
preid
SoCal
The blue black is easy to fix one self. Change the color to a lighter blue in the .dfg
The zoom level remains a problem for me. Truthfully I needed to pull out a chart to see what the altitude for a class C was as I zoomed out so far I couldn't read what it was on the bottom when I was flying the top of the section. Not knowing how hard it is to move/float the numbers more I would find a great benefit if it can be done. It's a big country so I gather it can not be all that easy
I believe the point Karl was making is that support did not comment on making any changes to this in the next release I know jake mentioned there was a "bug" but nothing from Dynon on if that is actually the case and what the bug is..
Per the other thread there is no indication this is in the next release
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1355974705.
The 'bug' may just apply to us downunder however IF there are other airspace issues then I'm guessing they may be fixed in the upcoming update  :-/
Jake J
There isn't any change to this behavior in 5.0 - it's not an easy fix. That means that there are a few some airspace segments in some busy places where you won't see the airspace shelf altitudes. But, know that there is work being done to mitigate it via other UI efforts that are going on.
Juvat
Goodyear, Arizona
reidvator said: The blue black is easy to fix one self. Change the color to a lighter blue in the .dfg
Please explain--I don't understand what this is. Thanks.
SkyView 5.1 update is out! Among the small things that it should fix, the companion settings file that's available on the download page (and included in the packaged updates) should improve the blue color of Class B and D airspace text (floor/ceiling heights)
User data logging and Stadium TFR support are the two feature additions. All of the little things are covered in http://www.dynonavionics.com/docs/WhatsNew_SkyView.html
Download the software update at http://www.dynonavionics.com/docs/support_software_SkyView.html.
Updated documentation for the 5.1 release can be found at http://docs.dynonavionics.com.
