Computer DB9 Connections
Nallin
Hey there.
In order to mantain the DB9 connector from EFIS and the DB9 connector from EMS avaible to laptop connection we want to jump de wire from pin 2 (EFIS) direct to wire from pin 3 (EMS). Will be there some problems in data transfer?
The easiest way to criss-cross pins 2 and 3 is with a serial null modem. They're only a few dollars from radio shack. The, when you want to hook up to a laptop for firmware upgrades, you just pull the null modem out and you have direct access to both PC connectors.
Nallin
I need to know if the EFIS wire 10-DB25 ( wire 2-DB9 ) is jumped ( not by connectors and yes by jumping the wires ) in the EMS wire 12-DB37 ( wire 3-DB-9 ) , will I have problems while the notebook transmit or receive to/from EFIS/EMS ?
Yes, you will have problems. You must be able to disconnect this jumper during an update from the PC.
