sstearns2
I'm connecting an HS-34 to a GNS-430 as shown on the wiki site, but I'm trying to figure out how to connect the trutrak A/P in with those two. The trutrak manual doesn't address the HS-34, but shows connecting the autopilot to the ARINC and serial outputs of the GNS-430.
Will it work to splice the ARINC lines out of the 430 and send the data to both the A/P and the HS-34 or should I connect the HS-34 ARINC and serial outputs to the A/P?
I also have a Garmin handheld wired to the HS-34 that I'd like to be able to drive the A/P with via the HS-34 if that's possible. Will the HS-34 output ARNIC and serial data based on what's being displayed on the HSI?
Hope this makes sense... Thanks!
Scott
Scott
