Connection Skydemon to AUTOPILOT D-180
Skylane 5
Hello everyone.
I have a problem with the AP functioning according to the Skydemon navigation instructions. I have the D-180 connected to the Skydemon using a Serial data cable from the EFIS D25 sub and a BT adapter NIXON BT578_V3.
In the D-180 menu, I have set the SERIAL PORT to the NMEA / BAUD RATE 9600 values. The NIXON BT578_V3 also has a BAUD RATE of 9600 bps.
In the Skydemon settings, it is confirmed that it is connected to the D-180. This is also displayed on the D-180 HSI in the form of purple symbols.
The AP works correctly in HDG and ALT modes. The moment I enter a route or waypoint in the Skydemon and switch to TRK or NAV on the D-180, the AP does not respond to these commands and the aircraft spins in a circle.
Where could the problem be?
Thank you for your Help.
