D-180 aileron trim not shown on EFIS
jbrady
Set up my trim calibration today. Both elevator and aileron trim set up as per manual using GP1 and 2 - with the numbers changing as the trims were run to ends and center so the connections are good. However when I display the EFIS screen, I expected to see both elevator and aileron trim as depicted on page 6-6 of the manual. But the aileron trim is missing. Any ideas please?
jbrady
A more basic question then please - The pilot guide only mentions the elevator trim scale on the EFIS and the installation guide mentions only elevator and rudder.
Is there/should there be an aileron trim scale on the EFIS once I have followed the configuration and set up instructions?
John
The single widget on the EMS pages should show both axes (or all three if installed) as described. Ae both GP inputs named correctly? (IE, TRIM AILRN and TRIM ELEV?). However, the EFIS page widget (overlaid on the actual PFD) is elevator only.
jbrady
brilliant - that solves the lost trim - I was only looking at the EFIS page not the EMS.
