I just purchased a D-180 which was upgraded to SuperBright by the Dynon factory to replace my (rather dim) D-180 in my Vans RV 7. I'm assuming that the replacement should be "plug and play" since my installed and working properly older unit is calibrated and connected to a D-120 through the DSAB bus. ;I will use all of the existing harnesses and simply plug everything in the new unit exactly like it is plugged into the old unit.
What re configuration will be required when I install the rebuilt Super Bright D-180? Thanks....
