D100 airspeed incorrect and fluctuating enormously
swbeyer
The airspeed indication problem came up with my latest flight and had been normal previously.  I first noticed something unusual at boot up when a message indicated something about the artificial horizon after which airspeed showed a steady 35 knots with the stall warning sounding even though I was still parked.  I recycled the system and it came up at 25 knots.  I had experienced a similar problem about 2 years earlier and it cleared up within minutes after takeoff, so I proceeded with my flight.  Once airborne the airspeed remained low for a minute or longer before steadily rising, ultimately becoming perhaps 20 knots too high, then got rapidly lower and registered zero for a minute or so.  The wild fluctuations continued and by the time I landed, even in my flare the airspeed showed 120 knots and when I parked it was still around 60.
What could be the problem here ?  Any suggestions on what I should tell my mechanic to proceed with ?  Could it be the connections to the pitot tube ?  Or does it sound like a problem directly within the D100 ?  The plane is a CTLS, just over 3 years old.  Thanks for any ideas you may have.
Re: D100 airspeed incorrect and fluctuating enormo
Did you disconnect the pitot/static lines at the instrument & have the 'mechanic' connect a pitot/static test box directly to the Dynon.  Doing each check will determine for sure where the fault is  ;)
Jake J
swbeyer
Ok, I'll have the mechanic test the D100 directly with his test box .... does my problem description sound like it's a D100 problem ?
swbeyer
I'll report back on what the problem was when it gets fixed. Thanks for your input.
First, disconnect the pitot/static lines from the back of the unit and look for water or other obstructions in the pitot line. If that doesn't work, give tech support a call or an email for further assistance.
