D100/ GPS/ Autopilot failure.
RV10flyer
On my RV-10, I haven't been able to get AP74 autopilot to capture GPS signal with D100 since last software update last year. A/P works fine with VOR.
A separate problem happened only on the last flight: Airspeed very high throughout flight (50 to 70 knots higher that shown on conventional airspeed indicator).
Any suggestions?
When you use the NAVSRC to select the GPS side of things, is there a CDI that appears?
For the IAS issue - IAS is pitot / static based, so if there is water or another obstruction - more likely on the static line side -
that is causing it to deliver lower pressure to the ADAHRS than is truly there, you'd see artificially high IAS. Was altitude behaving normally?
