In my Lancair 320, (GTX330ES xponder) to solve an ADSB intermittent failure issue, I switched from an old parallel data encoder to the serial data encoder of the D10A which solved the problem. However, after about a year and a half, I began having ADSB failures again, related to baro-altitude. (This from the PAPR following a flight) I then switched from the D10A encoder to the D6 encoder and the issue resolved.
I suppose this indicates a failure of the D10A encoder which may mean another trip back to Dynon for repair. Has anyone else experienced this with the built-in encoder? Is there a chance that a software update might solve the problem rather than an expensive repair event? I did not include the serial data lines when installing so I’d have to go back in and add the data-in lines. Thanks in advance for any info.
KEPM
KEPM
