D10A stays in a reboot cycle
blueflyer
My Dynon D10A will not get past the blue start up screen, then the screen goes black for a second, then the blue startup screen comes on again.  The white "d" for dynon does appear on the blue screen.  It stays in this cycle until I pull the breaker.  What should I do, send it in for repair?
That may be a voltage issue. Is it installed & what is the system volts ?
Did you also check it out by removing the backup battery, if fitted ?
If Jake's excellent troubleshooting tips don't help, we'll need to see it here. Give our support team a call at 425-402-0433 or email at support at dynonavionics dot com if that's the case.
