Carl_Froehlich
- Joined
- Aug 22, 2007
- Messages
- 324
I repeated a four leg GPS run in my RV-8A today. The error I previously noted in the Dynon D-10A TAS indication has remained constant. The D10A TAS reading was 9 knots higher than actual at 4500 feet (194 versus 185) and 6 knots higher than actual at 7500 feet (191 versus 185).
I checked the D10A outside air temperature reading with a second instrument. The readings were within one degree of each other (33 degrees F). The D10A altimeter reading was the same as a second instrument, and compared reasonably well with GPS altitude. The D10A indicated airspeed reading was the same as a second instrument.
As you would expect, the D10A wind speed and direction indications carried over the TAS error. As I really like having wind speed and direction feature on the D10A, this error is the most annoying.
Any suggestions on fixing this? Am I the only one with this problem?
