D10A with GPS-251
Taildragger
I have a D10A with 251 GPS recvr.
Can I tap off the GPS-251 TX line (pin 10 at the DB25 of the D10A ?) to send NMEA data to another device?
I love aviation!
It is typical with a dual Skyview system to split the serial connection to both displays so but I am not sure of the baud rate and protocol from the GPS-251. I think you would need to use a serial TX out of the D10A, if available, and configured for the correct baud/protocol.
If it's an experimental install, no problem. The GPS-251 outputs NMEA at 9600 baud.
If an STC'd installation - that kind of connectivity is outside of the scope of the STC, and so you really can't do it.
