D120 shutdown
Just had a D120 shut itself off a while after engine start, engine battery and charging system was ok.  Turned unit back on and all now ok - Is there anything I can check if this problem presents again ?
How did you turn the unit back on? Did you remove/reapply external power, or just press the left button?
That's hard to explain if the unit shut off and stayed off, but then did turn back on in response to pressing the left button. We could take a look at your unit here if the behavior continues.
The owner just pressed the button to turn it on - has about 90 hrs on it since installed. We could wait and see if it happens again ?
Sounds reasonable. Perhaps it was a power glitch - hard to say for sure. If the behavior continues, we'd want to take a look at it for you though.
